X,Y&Z Material Probe Code
Steve Geth
Nov 13, 2023
Hello all,
I am trying to put a touch off probe to use on a Fagor 8055 control. I have the attached short program together and it works perfectly for edge find and zero set for X & Y, but Z is setting the offset to .5 on the DRO at the conclusion of the program run. I have Z lifting .5 prior to the X,Y zero move to get it up off of the material/part, but I want the control to set 0 and then lift so I am not dragging the probe tip across the top of the material. I am very new to all of this and would appreciate it if someone can look at this and let me know where I am going wrong.
Thanks,
Steve
  • X,Y,Z Material probe.pdf
