Dickie Frank
- Jun 13, 2023
- Toronto, ON
I have a 2021 Haas VF-2SS with a 15K Spindle. A lot of our programs run between 10k-13k. Our warmup program ramps up to 15k over 20 minutes and traverses all the axis.
Questions:
- Can I stop at 13k in the warmup program since we never use the spindle at that higher speed?
- Are there pros/cons to running the spindle all the way up to 15k in the warmup program?
- Is ramping up to 15k unneccesary wear and tear on the spindle?
- Is it bad for the spindle if we never run it at top speed (required for proper lubrication or something)?
For context we use a lot of small tooling and used to run at 15k all the time but the spindle failed the day before the machine turned 2 years old. Haas warrantied the spindle, but I never found out what the issue was...I assume it was a bearing? Since then we've dialed back our spindle speeds out of fear of killing the new spindle.
Thanks in advance!
Questions:
Thanks in advance!
