I am not a fan of digi measuring equipment for the most part.
As example, I posted a pic the other day of 4 non-working 1" mics.
3 of which I bought new, and I typically only use them for really close work, not for general work - normally...
But when I needed to buy a 24" caliper, I guess I don't recall the reasoning, but I ended up with a Fowler digital, and the more that I used it, the more it impressed me. Much of the time that I used it - it was very tight work. (bearing bores and such) I would qualify the caliper prior with a mic standard in the range I am using it in. And then also compare with a mechanical mic as well.
I have seen them be maybe .002-.003 off at some point, but I wouldn't expect a dial to be any better 20" from the zero point... But many times they would actually be spot on.
After 15 years, they finally up and died one day. I looked around to see what my options were now-days. I don't recall what the quote on new came in at, but it seems like it was 4 digits for a Mit or Starrett?
I was about to break down and order one, but then I decided to see what I could find used on ebay. Lots of no-name new stuff for cheap, but ... I just don't know that I'm that brave.... But I found a clean, used, one owner Fowler for cheap. It is obviously a newer model than my old one, but it certainly hadn't been used much - if at all, for $225 !!!
The wood case that it came in is plain junk, so I am using the case from the old one.
As for features:
A) I hate the fact that they moved the ON button to where I pretty much can't reach with my thumb, like my old one...
But I can git over that...
B) One thing mentioned above was the "too many digits - hard to read", this one is only 3 place decimal, with a smaller/offset 5/10's column. This is plenty of resolution for any caliper, let alone a 24". I think the old one had an actual 4 place decimal, but I think the 5/10's may be better. ???
C) Also mentioned above, I s'pose if you were using it constantly, and it goes dark 3 seconds before you pick it up - constantly - that could be frustrating, But for a 24" - my old one would stay "up" 'till the batt died. This one goes dark by it'self - pretty quickly, and I feel better knowing that. This one actually needs turned back on, but most of the 1" mics that I had would turn the display back on with any movement of the barrel. 6" calipers not that way?
So far I feel that this Fowler 24" digi is a very good unit, as was the one that I had prior.
I am Ox and I approve this post!
