hmw1972
- Oct 25, 2021
- Manitoba, Canada
Denis,
You would have to consider where you're measuring the spindle growth from. The headstock itself will also grow as it warms up. I discovered this soon after I installed the DRO scales on my HBM. The headstock leadscrew nut and locks are located at the bottom of the headstock. The DRO bracket that moves the scale head is located near the top of the headstock. One day I had the read out zeroed and then I ran the headstock for about half and hour without moving it. After a while the readout was up .0001" and then .0002" etc. until it settled at .0004". I shut the machine off and went home. When I came back the next morning it was back to zero. The headstock had grown .0004" taller from the warming. I would assume it got .0004" wider as well (it's as wide as it is tall), which would have moved the spindle toward the table. You would likely have to measure spindle growth relative to the table itself, not the headstock. Of course if you actually managed to get the straight edge perfectly flat by machining there would be no enjoyment from scraping it.
Ken
Ken
