Hi all, I normally post on the Schaublin forum as own a 135 which was documented through a re-furbish and modification to the troublesome Variator system which now has no oil feed and is free from leaks .
New to this forum as have just acquired an Aciera F3 and are planning the move it from its current home to my workshop.
I believe the machine is the early version but appears in good condition, no fancy accessories but has the tilt and angle table, normal head and horizontal arm too but alas no 'nice' extras like the high speed head, slotting head etc.
I have had a quote to move it and was somewhat surprised at the cost so wanted to ask if the F3 can be easily lightened by removing parts without causing large dismantling projects?
I know the head unit can be removed, table, tray, doors and motor fairly easily, what else could be removed and anyone know the weight of the machine less the items mentioned - think its circa 500kg fully loaded?
Appreciate any advise and help. The move requires a lift over a door threshold and down two small steps, a concrete path round the house to the front drive where a van can be parked. I have a 5T toe jack and a 500kg Slingsby (which lifts the Schaublin 135 with ease BTW) straps and a block and tackle - any other items ideally suggested?
Marc
Marc
