jordanhaugen19
- Nov 29, 2023
I have recently acquired a Romi EZ-Path lathe.
The Lathe seems to function fine when using the "Do-Event" function. I can do ROUGH cycles or THREAD cycles just fine.
However, When I try to write a program with a roughing cycle or a threading cycle for example, I get an error that reads "ERROR IN PRGM AT SEQ# ___". I do not believe I have any errors in my cycles that I am writing. I have gone back to the foundation and fully copied exactly what was in the manual as a test and keep coming up with the same error when I verify the program. I am starting to believe that this is a parameter or software issue.
Does anyone have any thoughts on this matter? I do not have any contact or information of a previous owner to lean on for expertise so I cannot confirm its history.
As a second question I am periodically getting an error that states "SYSTEM ERROR - POSSIBLE POINTER ERROR".
This will periodically come up when I am doing a ROUGH cycle under the DO EVENT function. It will come up during the rough cycle and still finish out the cycle just fine. If I home the machine it clears the error.
Thanks for the help!
