rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I have a consistent error 61 that shows up whenever I press the tool change button. It first started during a program run. The first tool change went fine, but the second one would not clear the white tool change light after doing the tool change, and error 61 appeared on the console. However, I could repeatedly do a tool change because the tool change light was on, but it did not clear the error. I tried running the program from start, and when the first tool change came up, error 61 shows up and the tool change light did not come on. I also tried a manual tool change, and as soon as the TC button is pressed error 61 appears. I tried a full reboot, power cycle of the machine, no help, same problem. I tried switching to horizontal mode before starting the machine, same problem. I swapped the tool change control pendant for another, no help. Any ideas?
