michiganbuck
- Jun 28, 2012
- Mt Clemens, Michigan 48035
QT[They need some serious cleaning. Is Windex, rubbing alcohol, and/or ammonia safe for use on these?] I would say yes. Ammonia mixed with water will evarporate very quickly and so less harm to parts and gauges. To be fancy distilled water might be be better than tap or well water. Most any mild soap should be OK to good. Chemical sprays like WD and break cleaner will cut grease but are often a health hazard so not worth the using. Best practice is to not use a plate for any common storage because moving things about is what wears a plate. Good to place a plate so it might be turned /rotated so the very same area is not over used. Good to remember skin and lungs take harmfulls into your body, best avoid this when possible.
$10. a gallon
http://www.americastoolcrib.com/MSDS/NB75Z9406.pdf?PAHDID=000000204440528&PARDID=778635979061311
$32. a gallon (Starrett) safer
http://www.americastoolcrib.com/MSDS/NS6081823.pdf?PAHDID=000000204440528&PARDID=778635979061311
$10. a gallon
