Not for mill parts.programming at the machines is better and faster than you think, i could get fusion 360 for $500, so its not a issue.
Using Fusion isn't programming at the machine.programming at the machines is better and faster than you think, i could get fusion 360 for $500, so its not a issue.
I programmed manually for the first year or so, 25 years ago, but I never did it at the machine, not even for the lathe. I think a pc is way better than a machine's control to program manually, let alone with Cad/Cam.programming at the machines is better and faster than you think, i could get fusion 360 for $500, so its not a issue.
well i hand write my lathe programs, then type them in the lathe control. it may not be fast, but i like to look at the part print while im hand writing the program.I programmed manually for the first year or so, 25 years ago, but I never did it at the machine, not even for the lathe. I think a pc is way better than a machine's control to program manually, let alone with Cad/Cam.
A mill is not a lathe.was planning on programming at the machine like i do on my lathe.
Unless you are just squaring up blocks or making base easy stuff you will want CAM.
Take a look at your lathe's CNMG-432 holder.
Typical program for me to do this end work is over 400-1000 lines of code and 8 to 12 tools. Want to hand edit this?
I do know one guy who still does it in notepad. He has canned "libraries" that he cuts and pastes. It is painful to watch.
Nice thing about CAM is that I can "tweak" the program, feedrates, stock per pass, adjust size, etc. and be up and running the new program in less than 5 minutes.
Lathes are so different and I totally understand hand programming these.
Much depends on what you are going to do with it.
Size is budget, room to fit and what the floor can hold. On that floor remember that in most cases it is machine weight plus weight of the lift truck.
I've also seen people buy machines that will not fit through the door. Big fun.
Arguably smaller machines are more accurate.
The truth and super sucky answer is that no one can tell you what will work best for you since we do not run your shop, know the parts, or know your future direction.
Have a friend with a 5 axis big enough to park your pickup truck on the table. Micron accurate and linear motors for super flying speed.
Neat but it would not work for me at all.
Bob
You will not program for milling competitively by hand these days, unless the work is stupid simple and in easy materials. All of my parts require dynamic milling and surfacing toolpaths. You can probably get away with fusion for a while, but you should be aware of it's shortcomings; there are plenty of threads here discussing them.programming at the machines is better and faster than you think, i could get fusion 360 for $500, so its not a issue.
floor space, yep not terribly huge. Ive got about the same size, adding about 1000 sq ft as its the max i can fit in the area.no p
no problem on space, front shop door is 12 feet wide 14 tall, shop walls are 16 tall, shop is 30 by 40, and im adding another 500 sq ft as we speak. i keep thinking about getting a Haas mini mill, or similar sized
cnc mill, just so i can get started and then see where things go.
thanks to all who commented on this thread.
Exactly!!!in my experience, the average part size is one inch longer than your machine travel.
people make problems, thats why im a one man shop.The usual rule of thumb is that you want a machine slightly larger than the largest part you ever expect to see. Not just most of your parts, but you want a machine to do 100% of your parts, and your parts are as big as your parts are.
One other aspect to consider however is how many machines do you expect to have and how quick do you want your turn-over to be? How many operators do you expect to have and how long or run times do you expect? You may find that you only need one big machine for the occasional part of such size, and then have two or three other smaller machines for the more common work. For sure take full advantage of your table size with multiple parts running on one machine, but floor space runs out real quick if you just buy big machines. If you can put two smaller mills on the floor where only one big mill would fit, you can be setting up one while the other is working. In other words, with the space you have, get as big of tables as necessary, while also trying to get as many spindles on your floor as possible.
Then definitely, for sure, get a live tooled lathe instead. Mills take constant feeding and babying. Even when robot loaded.people make problems, thats why im a one man shop.
i have a small van norman manual mill, i am needing a larger mill, and i want a cnc mill, not sure if i buy a machining center, small haas mini mill, or large cnc bedmill. big cnc bed mill would work for me, but if i get production mill jobs, i dont want to be the "tool changer".Then definitely, for sure, get a live tooled lathe instead. Mills take constant feeding and babying. Even when robot loaded.
A fast machining center would probably make the most $$$ an hour, on average.i have a small van norman manual mill, i am needing a larger mill, and i want a cnc mill, not sure if i buy a machining center, small haas mini mill, or large cnc bedmill. big cnc bed mill would work for me, but if i get production mill jobs, i dont want to be the "tool changer".
Or have one running Op 1 while the other runs Op 2.If you can put two smaller mills on the floor where only one big mill would fit, you can be setting up one while the other is working.
Go as big as your budget and facility can handle. (With-in reason). Big machine can make small parts too. Though with big machines & big parts comes the reality of having to handle those big parts. Got a forklift/hoist etc... Just buy a horizontal with a pallet pool and thank me later.I may get a lot of crap for this thread, but here goes. Small cnc mill or large cnc mill?, I want to buy a cnc mill, not sure if I should buy large or small.
What is the a average size part that most cnc mills machine. If a cnc mill could machine a part 7” long by 7” wide by 7” tall, would that machine work for the majority of cnc milled parts?
Notice
