alphonso
- Feb 15, 2006
- Republic of Texas
http://www.practicalmachinist.com/vb/cnc-machining/chatter-thread-cutting-machine-problem-305924/
Follow up on this thread. I tightened gibs significantly which helped a bunch. Then I changed insert style: ToolFlo FLT-3R-HCB AC22R(a positive rake). All chatter gone. All 18 pieces threaded, about one and a half parts per edge.
Moving on to next operation. Part sticks out of chuck some 45 inches. Now working in area of bed that has no discernible wear. Start to get intermittent Z axis lag errors at variable points along axis. Most consistent error is about .1 into Z feed move. Hhhhhhmmmm, maybe there is a problem with the overtravel cables or stop switches. Switches are a little gummy; a few shots of B-12 remedies that. Still getting error. Pulled cable out of raceway and checked continuity while bending cable from one end to the other. Don't find a problem here. Currently have the overtravel circuits jumped to take the cable out of the mix. Still get error.
Status LEDS on servo drives (Fagor ACS 30) have burned out elements so I can't get a real good reading of the error here. My best guess is either error 5 (motor overload) or error 8(ballast error???). Amp meter at motor wires does not indicate excessive amperage. 7.5 initial amps on a 15 amp motor. Problem doesn't seem to be here.
Just for fun, ran something else with carriage within a foot of the chuck. No error in 20 repetitions of program.
Bring carriage back to the 45-48 inch position. Errors return.
Wonder if the gibs are too tight out here on this end of bed? Kinda thought this might be the problem because I could see very little movement then a sudden jump. Loosened gibs some 4 or 5 turns of screws. Very minute improvement. Did this procedure once while watching the belt between servo and screw. Could see the belt winding up, then relaxing. Tightened the belt. Checked sprockets on motor and ballscrew. They seem to be tight. Stopped the wind up and jump. Checked the thrust bearings and screw pre-load. No backlash.
Checked ballnut to screw play. Not sure what it means, but when prying on carriage in same direction as last move, indicator shows .004 movement. Cannot pry carriage back the other way. Can hear the servo fighting this prying attempt. Same result when doing this in opposite direction. With power off, I can't get any movement of carriage that would indicate ball/screw wear.
This is where things start to get weird. Set backlash parameter to zero. Place indicator on bed to read carriage movement. Move carriage in one direction, zero indicator and move carriage in opposite direction in .01" moves with handwheel. Screen display shows .01" per "click" of handwheel.
Indicator readings:
First move: .001
Second move .003
Third move: .005
Fourth move: .004
Fifth move : .004
Sixth move: .009
Seventh move: .10
Subsequent moves: .01
The sixth and subsequent moves move at rapid to the last thousandth, then creep thru the last thousandth.
I think I have eliminated thrust bearings, ballscrew pre-load/stretch, worn balls/screw, loose belt, loose mounting of any other components in the setup.
This sequence of readings is repeated in either direction of movement.
At this point I can't think of anything else to check other than loosening the gibs some more.
Ideas??
Indicator readings:
First move: .001
Second move .003
Third move: .005
Fourth move: .004
Fifth move : .004
Sixth move: .009
Seventh move: .10
Ideas??
