I'd be willing to bet it's not all that hard. A hardened part would crack at the corners, not wear into a round hole.I’m sure this piece is hardened.
Great point! I’ll check not out! Thank you! Does anyone have recommendations of clearance needed to use the Loctite 606? I’m thinking about drilling out center and inserting a round tube that has a square 1/4” hole.I'd be willing to bet it's not all that hard. A hardened part would crack at the corners, not wear into a round hole.
Take a file to it and you'll see for sure.
If you are going to bore it, use HSS - carbide won't survive the interrupted cut.
Steve
Thank you for your reply and correction. So far I think this is my best option. I’m afraid I may break out into the outside threads when drilling, but I’m going to attempt anyway. The Chuck is at the point where it’s unusable. Here is a picture of the Chuck insert hole in relationship to the outside wall.609, not 606. Their main page is https://next.henkel-adhesives.com/u...tral-pdp.html/loctite-609/BP000000153471.html Tech data sheet is https://datasheets.tdx.henkel.com/LOCTITE-609-en_GL.pdf Here's a chart from that document. The tightest clearance is about .002". Ultimate strength is the same even with about .006. Pretty forgiving. Larger gap gives lower ultimate strength. There are also instructions for press fits. Shear strength is listed as 2300 psi
Notice
