PanheadBill
- Aug 8, 2016
Hello, First post.
I picked up a Hammond #2 manual surface grinder for the price of the P.M. chuck and gas to haul it 70 miles. The Ex-cell-o 1074 motorized spindle has been "worked on" sometime in the past and now I'm trying to rebuild it. The ways are in great shape, the table moves smoothly, and the oiling system works well.
As received, the rear (motor) bearings were noisy and the spindle could be slowed by "pinching" the tapered end of the spindle with my thumb and index finger. This seemed to be less powerful than expected for a 1 hp 3 ph motor.
The bearings were a mixed set one MAC mated with a MRC, a pair of Fafnir in the middle and a set 1 older and 1 newer MRC. The nose and middle bearings sets were assembled Back to Back while the motor's set was in tandem face out. In addition the armature sat 5/16" forward of the center of the stator. (maybe the reason for less than expected power?)
At this point I am looking for bearings that I can pay off in my lifetime, and need information on the preload and orientation of the bearings for this spindle. I really do not want to pay $80 to the guy on E-bay for the excello spindle manual for the information on page 35.
What I have so far is a partial list of bearing numbers (with assumption of a 10 lb preload)
57 bearing
From catalog info:
Excello/MRC XO-57-87-rbds
MRC (new) XO-57-rbds 10
Timkin MM57XWOCRDU E9013C
From my spindle:
MAC X750DF Thrust abce7
MRC XO57 D 53 C1 (Note: "3" of "53" hard to read so suspect)
Fafnir MM 57EX 50 C1
67 bearing
From catalog info:
Excello/MRC XO-67-57-rbds
MRC (new) XO-67-rbds 10
Timkin MM67XWOCRDU E9013C
From my spindle:
MM 67EX 10 c1
Any spindle dimensions/drawings and bearing info would be very helpful. I suspect that the front bearing spacer is about 5/16" too thick, causing the rotor to stator offset.
Also, I found a pair of excello 67-2 bearings on E-bay; does anyone know what the -2 indicates in preload?
Thanks in advance,
"Panhead" Bill
P.S. I forgot to mention that the motor stator checks out: no shorts, opens passes megger testing and the 3 phases are near perfectly balanced. The Rotor passes a growler, test so no open bars.
57 bearing
From catalog info:
From my spindle:
67 bearing
From catalog info:
From my spindle:
MM 67EX 10 c1
Thanks in advance,
"Panhead" Bill
