daily_grind
- Feb 28, 2022
Hi All,
To preface, I am very new to grinding and just started this position about a month ago, so please forgive me if I get any nomenclature wrong.
I have been tasked with getting our two grinders running production capacity, which has been quite the challenge.
My current issue is the Nitinol wire. From what I've come to understand, Nitinol sucks to grind. Glebar had completed part samples to prove it could be done (in house) and had shipped the very same machine they did the R&D on, to us.
This is the current setup:
Diamond Wheel-400 grit-resin core, Diamond Rotary Dresser, Mineral Oil Coolant
Once everything was set on the machine, I was maybe able to make about 10 parts before my tolerances starting drifting out, like the diameters were getting smaller across the entire profile. I'm not sure what the cause was for that.
I reached out to Norton, and a sales rep came in and told me I had the wrong setup for trying to run Nitinol. He suggested using a CBN wheel. He also pointed out that I wasn't dressing the wheel, which could cause issues. We're definitely not in production mode, so I haven't keeping an accurate part count. I guess my question is this, am I using the right wheel/coolant, and how often should I be dressing (silicon stick) the grind wheel.
