mhajicek
- May 11, 2017
- Maple Grove, MN, USA
Not all the time, but about once every half a dozen toolchanges, my 2017 CM-1 is showing an ATC shuttle motor electrical fault when trying to bring the umbrella to the spindle. If I manually pull the umbrella out, and then push it back far enough that it doesn't have a position fault, it will reset and be able to perform the toolchange. Much more rarely, it will have the same fault when trying to retract the umbrella, and again, moving it by hand will allow it to reset and continue. Anyone else have this before? Is it worn motor brushes, can you replace those yourself, and where would I get them without having to buy the whole motor?
Thanks
Thanks
