villageblacksmth
- Aug 4, 2021
I recently purchased a Romi M17 lathe. I certainly don't know very much about running it yet, but I am learning. Today I was machining a bushing on a tailstock supported mandrel up closer to the chuck. Before finishing, I shut the machine down and went home. After returning, I wanted to finish the project. I started the machine, and since I didn't want to slide the tailstock all the way to the end of the bed to properly home the machine, I decided to just slide the bracket with the sensor rod up in front of the tailstock. I then homed the carriage, but it only stopped when the sensor rod tripped the contactor. It didn't properly home. And, it doesn't appear to go into "Guide" mode unless correctly homed. Now, the carriage won't travel past where it was stopped. It alarms out, and won't travel to its true home position. How can I reset the parameters so it will again travel to the end of the lathe bed to the correct home position? Thanks to all who give advice.
