rwa2004
- Nov 17, 2017
- Western PA
Does anyone have a good set-up for using a laser for a straight edge? Not looking for the level aspect that you normally see related to lasers. I am imagining something that I can set on a surface and have a traveling indicator to read. I know accuracy will be limited as the laser beam as thickness.
Here is my background - I am asked to check straightness of 9ft aluminum extrusions with a straight edge. My thought is that if I acquire a 9ft mechanical straight edge it will only be good for about 1 week before someone swings it into something. Here is the stupid part, I am not given a tolerance. (Of course, this is a government job). I ignored this requirement for a long time because a requirement without a tolerance is a garbage requirement. I figure the part needs checked with a straight edge and match with +/- 3 ft (I get to pick my own tolerance, right?). However, I think my govt. inspectors are going to tell me I can't ignore it and I have to check with a straight edge even if I do not scrap any parts as a result. For this and a handful of things around the shop, I thought it would be nice to have a laser block and reader block set up and ready to use to set things straight. I have used laser levels, but they do necessarily have a specific beam-to-base height and are made to be adjusted to the level and not to the base. I am curios if there is a laser/reader combination set for the straight edge use I am looking for.
