I have a new and now recurring customer that brings me jobs that aren't necessarily in my wheelhouse but a path I'm willing to pursue and make an investment in. I'm considering the purchase of a mag drill as the work doesn't necessitate the accuracy of a Bridgeport or CNC plus in some cases are too large/bulky for either machine but not something to the scale of this post https://www.practicalmachinist.com/...-too-heavy-for-the-table.419209/#post-4147953
Current project is drilling 1-1/16" holes in a 6' long 4"x4"x3/8" square tubing which I'll do on my Bridgeport.
The Hougen mag drills are on my list but am having trouble deciding which model to purchase. I'm currently thinking the HMD905 with swivel base would be the most versatile. I don't have a specific type project in mind (beyond the one listed above) and this one has a 2 speed motor so I could use both HSS and carbide annular cutters, the size of the cutters it can handle are likely within what I would use it for and its weight is reasonable to move around. I am not likely going to be using overhead and hard to see a situation currently where I'd use it vertical but maybe possible.
Model info here: https://www.hougen.com/mag_drills/HMD905/HMD905_mag_drill.html
The other option is go big or go home and get the 3 speed HMD920. 10 lbs heavier but can pretty much cover any scenario.
Model info here: https://www.hougen.com/mag_drills/HMD920/HMD920-mag-drill.html
Part of my dilemma is I don't know what project they are going to walk in the door with, all I know is they keep walking in the door and I'd rather not turn down the work.
If there's another recommendation for regular users of mag drills that you suggest I'm open other models like the HMD904 for example that Hougen lists as their most popular model.
Models options here: https://www.hougen.com/mag_drills/mag_drill_index.html
I would be also purchasing a drill chuck with whatever unit I get.
Thanks for any input
