specnaz
- Jun 28, 2019
- Saskatoon, Saskatchewan
Any ideas where in Canada can I find the following? Called about 10 large companies and only thing metric they can get is shafts, while I need to quote a job that is fairly big but it's exclusivly metric sizing
30mm cold rolled shaft
25mm cold rolled shaft
12mm cold rolled shaft
2mm sheet metal
3mm sheet metal
6mm sheet metal
8mm sheet metal
12mm sheet metal
13mm sheet metal
20mm sheet metal
25mm sheet metal
30mm sheet metal
40mm sheet metal
50mm sheet metal
100mm x 50mm sq. tube
150mm x 100mm sq. tube
150mm x 150mm sq. tube
150mm x 250mm sq. tube
150mm x 350mm sq. tube
250mm x 350mm sq. tube
2mm sheet metal
3mm sheet metal
6mm sheet metal
8mm sheet metal
12mm sheet metal
13mm sheet metal
20mm sheet metal
25mm sheet metal
30mm sheet metal
40mm sheet metal
50mm sheet metal
