Put another way the vertical centerline should be parallel to the helix of the thread. For a single start thread your tool will work. As the number of thread starts increases the helix angle must get progressively steeper and the tool has to tilt more and more to remain parallel to the thread.The Dorian insert and toolholder is good for helix angles up to about 2 degrees, the thread you are trying to cut is many times more than that. The only way to get that tool/toolholder combination cutting properly would be to fit a 7 degree packer under the toolholder to tilt it over to the actual lead angle.
You're right, not sure where I got 20. Are you calculating from the major or minor D?Put another way the vertical centerline should be parallel to the helix of the thread. For a single start thread your tool will work. As the number of thread starts increases the helix angle must get progressively steeper and the tool has to tilt more and more to remain parallel to the thread.
The helix angle is Arctan(lead/pitch diameter circumference) so roughly 6.5 degrees.
As LexD says make a shim or you can mill the bottom of the toolholder and maybe the top as well if the shank needs to be parallel.
Aloris make a holder that makes this easy. The HSS insert tilts.
I'm not crazy about these tools but one would work for your situation.
Use the pitch diameter.You're right, not sure where I got 20. Are you calculating from the major or minor D?
Haha it’s funny you sent this. I actually have the tool but with the P-10 blade so I have the p-4 blade on order that should cover 4tpiPut another way the vertical centerline should be parallel to the helix of the thread. For a single start thread your tool will work. As the number of thread starts increases the helix angle must get progressively steeper and the tool has to tilt more and more to remain parallel to the thread.
Ya for single point measurement my go to method has been using 3 wire and getting between the min-max for pitch dia. Kinda slow but it seems to work.Excellent improvement, well done.
As far as DOC, measured vs expected, mine NEVER agree.
what's wrong with Mo-Max or Vasco Supreme?As an aside,currently available Chinese HSS is so crumbly ,you cant cut with a ground point ,as in threading........look in your glory box for a piece of Fagersta or Poldi Stahl and your threadcutting will be enabled.
Couple years ago I found some 1/4 x 1/2 x 6 Mo-Max on Amazon, 10 pieces for like $35. I have no idea how I stumbled across it but it was a heck of a deal and I now use that stuff for everything.what's wrong with Mo-Max or Vasco Supreme?
Mo-Max and Rex toolbits have my vote!what's wrong with Mo-Max or Vasco Supreme?
You really need a blade for 12 TPI. Remember pitch is the number of threads per inch, or 12 in your case. Lead is the distance the screw advances in one turn, or 3/12"=1/4" in your case.Haha it’s funny you sent this. I actually have the tool but with the P-10 blade so I have the p-4 blade on order that should cover 4tpi
Yes the nose radius, which I assumed would be too large for 12TPI.Not so much for the clearance, but yes for the nose radius. If he's going to be tilting the tool, I'm with you.
Notice
