Hi surplusjohn:
Yeah dentures were traditionally made from heat and pressure cured poly methyl methacrylate (PMMA) (acrylic)
However, in the last 10 years or so, increasingly dental labs are one-time injection molding them out of acetal copolymer.
The material is called "Zirlux" ...it's tough as shit but you can't glue it.
Its rarely used for full dentures but is increasingly common for partial dentures.
If the friend's denture broke, it's almost certainly PMMA.
Solvent adhesive might make a strong enough repair, but mostly these are fixed by sticking the halves together temporarily, then making a plaster index, then grinding a big vee at the break, then reassembling the halves on the index, then wetting the ground edges with methacrylate monomer, then wadding in acrylic putty, then heat and pressure curing the denture, lastly polishing the repair and re-fitting the denture in the patient's mouth by re-lining it and refitting the occlusion.
That's all a lot of screwing around, so many dentists and denturists will just make a new one.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
