Got this valve from Surplus Center. I've had it on my log splitter for a couple of years.
Leaking out the valve's rear cap. There is a square cross sectioned wiper or seal or whatever that has given up the ghost. It's basically a wiper/seal for the spool shaft.
#20, on the drawing, is the number of the failed item. In the exploded view, they call it only an "O-ring", with no mfr's part number. I find no kits for this valve.... WLS800.
Pictures below. It's a yellowish/clear looking material... polyurethane? Not hard... relatively flexible.
I don't know exactly what terms to use in a search to find these.
The valve spool diameter where this seal fits is .812".
The seal o.d. is 1.062. I haven't measured the bore itself.
The width of the seal is approx .140"
When the spool is assembled and inserted into the valve bore, seal retainer #21 squeezes seal #20 into the bore, and spring cap #30 holds it all in place.
Need to find one of these seals.
