BT Fabrication
- Nov 3, 2019
- Ontario Canada
I have my manual mill that blew the magnetic coil/overload on the motor starter contactor, only problem being is that its 600V and the coil was also 600V in an enclosure to hit start every time I needed to use it.
Yesterday it blew up and am having a hard time finding a replacement that will match it as all the others are lower voltage mag coils. mine is a self latching off the feed power once you hit it.
Its a 600V 3 phase coil powering a 3HP motor of about 6A, local shops seem to be telling me that the coil isn't normally 600V due to having 600V where you push the button. on the face of the box.
What's the alternative? replacing it with a 600V contactor and a lower voltage coil and getting another 600V to V? transformer and overload
Current one is a Danfoss CI-9 Contactor that is no longer made.
