rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I'm getting an error in D4 due to adding a G7 between a straight cut and a G3 arc. Not supported? e.g.
N5 Y-100.534
N6 G07 R5.0
N7 G3 F80 X21.763 Y-100.534 I21.763 J100.534
N8 G07 R5.0
N9 Y-67.937
That code raises error 90 on line 7. 90 says "G07/G08 programmed outside compensation on contour, 3D interpolation or interpolation with C axis blocked."
I'm not using G41/42 but I think the error is due to the 3D interpolation clause. Probably I should just do a 45 deg. bevel on the corners (not using G08) starting 5mm before the end of the straight cut.
N5 Y-100.534
N6 G07 R5.0
N8 G07 R5.0
N9 Y-67.937
