keon-inventor
- Jan 19, 2024
I know this may be a dumb question but I'm new to micrometers...
So if I have an analog micrometer that can measure up to 25mm (0-25mm), and only need it for measurements less than 5mm. And it came with those "calibration pins" for 25mm, but after getting two more of these pins from various sources, I noticed a ~0.03mm deviation between them, and I only need to take measurements <5mm.
Would it be possible to eliminate this 0.03mm deviation for measurement <5mm by zeroing it using a 10mm gauge block and then check the zero with 5mm and 1mm gauge blocks?
Or would I need to use a 25mm gauge block, then recheck with a 10mm, and then a 5mm and/or 1mm block?
Thanks
Thanks
