Rick_H
- Jan 26, 2013
- uk - midlands
Well just to set the story, my Dad works here at the shop on the Hurco VM10's and has been a little care-less.....
We use a 'cap' over the workpeice (all aluminium) to keep it flat, this is added when the machine comes to a stop with an M0 half way through, as you can guess this cap should not be there at the start of the programme (which he re-loaded without removing the finished work) and the 50mm face-mill plunged in at 7000rpm on rapid, it blew to bits as you can see in the picture before interpolating the 'cap' for a little while until i could run over and mash the stop button (It didnt overload and alarm out suprisingly)
Reset the stop, removed the massacred tool and started the spindle at 1000rpm and as i turned up the RPM I was met with a different noise to usual. The spindle now has a 'wine' that gets louder and higher pitched as the RPM increases.
I have checked spindle runout at the taper and it is well within spec, tools change as they should and I have had the belt cover off and nothing looks strange there, there is no rumbling or metalic noise and the spindle feels normal when turning by hand.
I will be putting a call in tomorrow to get a tech out, but in the meantime can anybody give me hope that i dont need to replace the spindle bearings in a machine that is less than 2 years old with low hours? Or is it wishfull thinking and the old man is in serious S**T!
