Hi team,
Long time no post!
Business is going great but once again I’m coming to my fellow PM team for some advice. We are stamping our own brass / copper parts now at a furious rate, however the stamping oil cleaning is a bit of an issue.
Anyone have any advice on the best way to bulk remove it without damaging the copper component? So no acids or alkaline.
1: We are going to try a simple detergent wet tumble then spin dry.
2: Detetrrgent tumble, rinse, metho or acetone bath to dry quickly.
3: Or dunk them in white spirit, tumble off excess then wash in detergent and water then tumble to get water out then dry.
I’m worried that if we dunk heaps in white spirit it will just saturate with oil pretty fast. Anyone else got any ideas, or does the oil float to the surface in white spirit so you can skim it?
Since part weight is critical (+/- 0.006 grams) I have found using acid washes problematic as it attacks the parts and leaves variance. If I could get the bulk oil off maybe a bit of acid in the wash for 5 minutes MIGHT be ok. Have to try.
Hope you guys can help me with a process. Thanks!
Long time no post!
