Archstanton
- Nov 26, 2023
Hello I’m considering purchasing a standard modern 1334. The seller has no power where it is stored so turning a test piece is out of the question. I did however place indicators on the carriage and checked the bearing surfaces from the headstock to the tail and the results were a .005 variance. Opinions? is that good? Great? Or complete crap? Can this be an accurate way to check for bed wear? The machine seems to have normal wear and tear and it may have been turned over at one point due to the fact that the gear change has been repaired. However it seems to be a steal @$1500. I should add that I’m purchasing a lathe for barrel threading and chambering. Thanks
