dalmatiangirl61
- Jan 31, 2011
- BFE Nevada/San Marcos Tx
I returned to the home/shop last night to find I had lost 1 leg of the 240v single phase power coming into building, power co was called and they found a wire connector at transformer on pole was burnt, quick easy fix. After repairing that connector they wanted to check power coming into my place so they pulled the power meter and started probing terminals. L1 to L2 240v, L1 to ground 120v, L2 to ground 120v. But when they probed L1 input terminal to L1 output terminal it showed 27v, and L2 input terminal to L2 output terminal showed 20v??? The guys first comment was "you must have forgotten to turn off a breaker", I then pointed out that main disconnect was 10ft away, and it was open.
So I'm trying to figure out why there would be voltage the way he tested it if the main disconnect was open, it makes no sense to me. Next question is, is this a problem? If it is a problem, what should I be looking for?
