Steve Geth
- Nov 13, 2023
Hi all,
I set up my CNC knee mill with two probes. A material/ part probe and a tool setter probe. I am having a hard time grasping the setup for Z probing and tool length offset and hoping someone can explain what I am doing wrong.
Here are my steps:
Home the machine.
Set the tool offset for the probe (tool #16) to 0.
Move the axes over a hard block that is the exact height of the tool setter.
Using a simple one line code, Z- until the probe is triggered.
Press F1 (Fagor Control), then Z, then Enter, then Esc to set the tool length for the probe.
Move the axes above the mounted material and run a Z probing program that does a material touch off and sets G54.
ISO G54 to make the tool active.
T1 cycle start to move the axes to the tool change position
Change to the first cutting tool, cycle start to accept the new tool
Run a probing program that moves the axes such that the tool is above the tool setter, slowly moves down until triggered, I hit F1, then Z Enter, then escape to set the new tool length.
Fundamentally, everything works, but the numbers that I see are confusing me.
With the material probe (tool 16) from Z 0 to the hard block I get Z-1.97 (which I set as the tool length). I then move to the mounted material and Z down and get Z- 1.52 to the material surface and G54 reads .450 which makes perfect sense indicating that the material is .450 higher then the hard block and tool setter. I then ISO G54 to make the tool active and the Z DRO changes to 0 which also makes sense.
Now, I change to tool #1 and run the tool setter program. When the tool setter is triggered, I again hit F1, Z, then Enter, then Esc to set the new tool length. The tool length for that tool now shows Z- 2.65. When I look at the Z scale on the spindle, it shows -2.20 I recognize that 2.65 less .450 is 2.20.
My confusion is this: My thinking is that whatever the value is for the tool length of a given tool in the tool offset table, I should be able to start at Z 0, (Z fully retracted) go to ISO and enter that -Z number and cycle start and the tool tip should be at the material surface. Is my thinking incorrect?
if I were to do the above starting from Z0, the tip of the tool would be at the tool setter height, not the material surface which is .450 higher.
Please let me know if I am doing something wrong, or not thinking this correctly.
Thanks,
Steve
Here are my steps:
Home the machine.
Thanks,
Steve
