Use fingers until you get to 10 then start on the toes.By the number of teeth
Can I help:Use fingers until you get to 10 then start on the toes.
You have a module 1 rack? Then every module 1 gear (with the same pressure angle) will mesh properly with your rack.I need to know the number teeth per inch or mm to get the correct spur gear.
How is the number of teeth counted in a mod 1 spur gear rack?
That does not help with the spur gear I need. Sure, I can count the number of teeth. How does that help in getting the correct spur gear? In 30 mm there are 10 teeth. Pitch is 2.27 mm.
Notice
