I'd like to try making new sealing head unit for mtb fork damper (OEM version has a lot of friction). Hobby lathe project.
Can someone help me with desingning choices?
Let me start and give some background:
- working fluid: hydraulic oil
- 10mm alu anodized shaft
- 2-4 m/s max speed or so (80-160 inch/s), longitudinal movement, zero rotation
- total 100% leak free is not needed
- significant side load, hard to estimate in numbers
- shaft will be backed up with bushing
- lowest friction is the key point
Now questions:
1. Should I go with o-ring or u-seal?
2. Is delrin ok for bushing? Is there an andvantage with maximum possible length of the bushing?
Now questions:
