Have several old Madison or Madison-type spade drill shanks shown, no blades/inserts. Someone apparently adapted two to shorter inserts with a key stock spacer. For larger holes we have twist drills but I’m going to invest in a set of annular drills to use in the Bridgeports. We’ve never used spade drills for metal and understand they take lots of pressure and use lots of hp. So I think I’ll just carve up the old Madison’s when I need something similar, maybe boring bar or whatever. Any reason I should refurb the old Madison’s including trying to find inserts that’ll work?
