HcraftsmanM
- Oct 27, 2023
Hi all, new forum member today.
I have a Hercus (Australian made version of a Southbend 9") metric lathe with metric quick change gearbox and 3mm pitch leadscrew. Also have a complete set of change gears to facilitate imperial thread cutting which I use occasionally. Fortunately, this includes the old style 120/127 tooth compound idler which to accurately produces imperial treads without the minor pitch error normally encountered when using a 63/64 compound idler for the same purpose.
This got me thinking if I could use an imperial thread chasing dial by replacing its drive gear with a 32 tooth gear (3mm pitch). Would the modified imperial thread dial then work as it would on an imperial gear/lead screw lathe? or is my reasoning flawed?
FYI - haven't tried this yet but the metric thread chasing dial I have has 3 gears - one of which is 24 tooth. I'm guessing some of the marks on the dial will synch with some imperial pitches if using this gear as well.
There's heaps of info regarding imperial to metric thread cutting but not much about meteric lathe to imperial.
Any comments would be appreciated.
Cheers - Fred (Tasmania) - beer o'clock time
