Job Shopper TN
- May 17, 2015
- Southeast TN
Hey folks. I need to bounce an idea off of some more experienced maestros. First, a little back-story:
Our shop has two slant-bed CNC lathes, both Haas, an SL-20 and SL-30 Big Bore. Both are of early 2000's vintage. The SL-20 has a bolt-on style turret, the SL-30 has a VDI40 turret. Neither have live tooling or Y axis.
We constantly have problems with these machines when using drills or other similar tools, in particular the SL-30. As I'm sure by now you can guess, the problem is alignment with the spindle centerline.
Only a few weeks ago, our maintenance man spent a day to clock the SL-30 turret in line. I double-checked him, he had every hole on the turret at no more than .002 TIR, mostly .001. Well, here we are, fixing to run a big production job, and it's been moved already. The couple of bores I could check were out .008 - per side, in what would be Y. Worse by the time you add the tool holder, ER chuck, and the tool. With some variation depending on clamping the tool, I got up to .012 runout on the drill - PER SIDE! If that were in a mill, you'd be into interpolation territory!
Pretty bad! The upside is, we can move the drilling operation to the mill, where the part is headed anyway after turning, and it turns out said drill can run a heck of a lot faster when you aren't limited to 2000 RPM...
It appears evident to me that simply re-aligning the machine won't do, as the least little thing would appear to move it. I'm kicking around a sort of workaround for this. At this point I would add, standard operating procedure for us when putting a drill in the machine is to indicate it to center. I would love to just be able to push F2 and be comfortable with it - but it just isn't so.
My idea is similar to a four-jaw chuck concept. Since the tool holder won't repeat, it needs to be adjustable.
So - I'm thinking, take two certain tool holders/blocks and bore them to have .020 or so clearance on a 1" straight shank (so, bore to 1.02" I.D.). Then add in a third pair of set screws. The holders we have have set screws on the front (X-) and top sides (Y-?). Doesn't do a dadgum bit of good when your drills are always low! So add in a third pair of set screws from the bottom.
My thinking is - pushing the tool in, and aligning the flat, with the set screws from the X- side should align the tool straight at least in the X axis, perhaps also in the Y axis (straight, but not concentric). Then, the top and bottom screws allow for adjustment of "Y", potentially allowing the tool to be indicated - as our owner says, mortus testes... dead nuts!
I'll add a final observation. As our SL-20 has a bolt-on turret, it already has a pair of set screws on both Y sides of the block. All it needs is the clearance.
I know it probably sounds horrifying to have to indicate even a simple drill, and I wish there was another way. I'm open to suggestions on any front (other than "buy a better machine", not in the budget, wish it was!), whether it deals with my concept or not. Have at it!
