Understood and I'm nodding my head in agreement. I have a short run and only two connected drops on my main DC line. They are connected to the jointer/planer. I leave those both open to try and reduce the load but there is most definitely still a load. The impeller is pulling air, no matter if wood chips are being pulled with it.Yes.... However, the dust collector is not a "pony". Unless all air flow is cut off, it is a "load", and will not produce much, if any, output on the generated leg.
I'm seriously considering trying to have my high voltage motors rewound and trying to find someone who can help address/explain the control panel on the back of the planer. I'm going to rewire the DC for 220 since it's the only motor labeled dual voltage so I can pull that off the transformer.
There will be more 3 ph. machines in my future so I'm uncertain the best course of action.
Upgrade to a larger RPC? Consider something like a Phase Perfect? Are they robust enough? I believe they no longer support older models, that scares me a bit.
