AllenHunt
- Dec 15, 2020
- Kentucky, USA
I'm attempting to take the apron off of my Lodge and Shipley Model X lathe. Taking the feed levers that resemble cow udders off of the apron exposes the shafts for the longitudinal and cross feed engagement. Around those shafts coming out of the apron are brass bushings with wider collars up against the apron and those bushings have internal keyways keying the bushings to the shafts going into the apron. Those brass bushings seem to to have a unthreaded hole on the collar which is up against the apron. The unthreaded hole doesn't seem to have a set screw at the bottom, but it is hard to see down the hole. I tried all of my imperial hex wrenches, down to the smallest wrench size, and none of the wrenches tries to engage a set screw that may be at the bottom. I was thinking that the hole might be a clearance hole to a lower larger bore that is threaded, maybe to hold a captured set screw at the bottom of the hole. After trying to engage a set screw with the hex wrenches and not feeling any engagement down there, I don't think that there is a set screw down there. Now I'm thinking that maybe the hole is there to insert the bent end of a small round bar to use when pulling the bushing off of the shaft. There is no room between the collar of the bushing and the apron to use for prying the bushing off. I'm posting to see if anyone has a thought about this before I try pulling those bushings off. I do have the parts manual, but I think the diagrams don't match these bushings exactly. I am worried that the oil pump is not working.
