FrodoLoggins
- Nov 10, 2019
Issue 1:
When touching off tools, the spindle always moves up to Z max before starting to plunge down to touch off the tool. Previously, the spindle would not move up prior to probing. This occurs both if the tool I'm touching off is already loaded into the spindle or if the machine needs to change tools prior.
IMG 4542 - YouTube
Issue 2:
Touching tools of sequentially will only do one at a time and only that one tool. If I specify to touch off tools 1 through 9 with the sequential probing cycle and hit the green go button, the below sequence will happen (assuming tool 1 is already clamped inside the spindle):
1: Spindle moves up to max Z.
2: Spindle plunges down to touch off tool 1.
3: Tool 1 is touched off.
4: Spindle moves to max Z.
The tool never gets changed. Tools 2 through 9 never get probed. Hitting the green go button again just touches the same tool off lol.
I'm assuming installing the newest version of the control's firmware will revert whatever dumb settings I might have changed lol?
EDIT:
I got all new 9xxx programs from my HFO, pasted them to the control, then locked editing them.
IMG 4542 - YouTube
Issue 2:
EDIT:
