acakololec
- May 15, 2023
Good day
Respect to all.
I have a problem with the power supply from the title. I located the fault by elimination method and found that the problem is in the servo board (bosch 052303-4047), attached picture.
I need help, how can I test the board without power, or if someone can direct me where to look for a fault. I should note that I replaced all the electrolytic capacitors, checked all the diodes.
Thank you
Respect to all.
Thank you
