magno_grail
- May 29, 2014
- ca, US
Hi, I am prototyping a motorcycle clutch basket and need to broach the slots for the plate tabs. The plan is to use Z moves with a parting tool to shave the slots with the basket on a rotary table. The problem is the spindle lock allows the spindle to rotate slightly so I need a way to hold the spindle in one position. My thought is to make a ring that will use set screws around the spindle nose (or a split ring with bolts clamping it) with a flat bar screwed to the side of it. Replace the tool holder set screw with a threaded rod that goes through the plate with nuts on either side to lock it in place after the tool is tightened.
Any better suggestions (other than taking it to a broaching shop who will not have the right broach anyway)?
Thanks
Thanks
