Pat Murray
- Nov 25, 2006
- Santa Fe, Texas
Kind of curious, Would it be better to cut all of the "front" side profile cuts on a lathe, drill, then bore the hole to correct size, Saw cut the slots (possibly even with bandsaw). Then return to the lathe & part off...?
I'm always a little concerned about running small or springy parts. They have a tendency to jump out of the chuck at the 99.9% complete stage... For this reason I'd try to part off last and keep as much of the stock attached as long as possible...?
I cut a 316ss camera housing 1 inch OD with O-ring grooves and a few relief cuts for a tiny underwater Camera and 28tpi external threads in similar fashion... After several attempts to chuck on the thin flexible part with no success, I decided to make all of the external cuts first then move to the ID and Part off last...
I'll try to find some pics...
Pat
Pat
