Doozer
- Jul 23, 2001
- Buffalo NY
Limitations of a cheap model are the centering accuracy of the vee block.@DouglasJRizzo - So you were "content" with an inexpensive one? What would you say that it's limitations are and are you glad that you didn't spend the extra $$$?
I think I'm in a similar boat to your mindset at the time...
on a regular single slide model, you get the centering accuracy that it
is made with. Then their is angular coaxial accuracy, or how parallel
are the working surfaces of the vee block to the axis of rotation.
And then there is roundness of the rotation, a function of the bearing
races, and balls.
Another way to say it, how straight (non tapered) do you want your part
and how round do you want your part and how symmetrical do you want
the features on your part.
If the accuracy of these things is not needed per the specs your parts
are required to have, or you do not mind the aggravation these
inaccuracies cause when setting up a part in the tool, then you may
be ok using a cheap one. People who own a good one know how
much of a benefit it is not fuking around every time you use it.
If you buy cheap all the time, you are usually walking around
frustrated all the time. I have learned there are many other things
in life that can frustrate you, and for me, owning cheap tooling is not
going to be one of those reasons. It is called WISDOM. Some people
never acquire it.
-Doozer
