bentwrench
- Oct 25, 2007
- North Dakota
I have been trying to figure out why my heavy 10 vibrates at higher speeds, it is a slow oscillation that cases the headstock to sway back and forth. It only happed at higher rpm, but seems to happen in every gear. My machine is on a VFD.
I thought perhaps that unevenness in the belt was causing it, but I put a dial indicator on the cone pulley and found .010 runout. It is worse on the large pulley but still .006 on the small diameter. Has anyone seen this before? Is this normal for flat belt pullies.
I an going to investigate the underdrive next, but I was surprised to see that much runout on the spindle cone pully. I did pull the bull gear pin and rotate the spindle while holding the cone pulley still, and had zero runout so it is the cone pulley and not the spindle itself.
