Yes, you don't see Intel re-working chipsets much, nor even PCB's.Hi Strostkovy:
Yeah your reasoning is sound.
Also worth considering is that setting up a complex part where the clamping surfaces have been milled away, or the part has been sliced from a holding block, or you don't have the fixturing they have, can make the repair more expensive than just biting the bitter pill and running a new part, even from scratch.
Some of the stuff I make is impossible to modify once it's sliced off from its handle...it's way too small to hang onto conventionally, so once it goes on the wire for the cutoff, it's done, and if you fucked something up along the way, it goes in the garbage, even if it's something simple like a hole that's a few tenths too small, or a surface that's still a few tenths too high.
Yeah, you wish you could just set it up again and whisker off the bad bits, but too often you just can't.
Cheers
Marcus
www.implant-mechanix.com
www.vancouverwireedm.com
Easier to simply push the start button on the machinery already set-up.
