michiganbuck
- Jun 28, 2012
- Mt Clemens, Michigan 48035
From the clearance chart plate at the below post you see the above or below wheel center one would position the wheel to achieve the desired clearance. (Diameter X clearance x 89 = above or below.) That would suggest having the wheel OD facing the part.
RE: 3 inch wheel x 7* x .89 + 185 (actually 185 but plenty close enough.)
That keller was a rare machine likely because the also rare Cincinnati radius/profile grinder and the Cincinnati Monosei were easier to use/ understand.
Making a pivot location pointer/ gauge should make quick setup possible.
Using the Od of a grinding wheel will make a curve acr in the part..using a recessed wheel. a flat-dressed cup or dish wheel on the side face will make a straight /Flat grind.
The angles plate is the 4th photo going down.
Hi everyone, A friend of mine just purchased an interesting old machine, and i was hoping to find out a bit more about it. We haven't been able to find any reference to it so far. The tag says "Keller Die Sinking Machine" by Keller mechanical engineering Corp. It's equipped with a weldon...
www.practicalmachinist.com
The Cincinnati radius/profiler machine had a straight (Type 1) wheel set verticle that would rotate and travel ahead and behind its pivot center to achieve a radius..The part be raised or lowered to the where to achieve clearance.. The wheel travel (left and right)could be set free left or right travel so a trace could follow a form template..one could follow a form, make a radius and continue to make more of a form..It was a little tricky because the operator had to eyeball judge the position of work head pivot being well centered..often one was lucky to make .001across the form and radius. I have only seen and used one of these machines..likely hard to find one today.
The Monoset was the survivor, likely because it could make a helix and became popular for that feature. A good shape Monoset can do almost anything.
