I’ve just finished an install of a DRO on my Hercus 9” C lathe and I’m noticing some weird behaviour that I need some help to further test. I suspect having a DRO has highlighted a problem that has always been there but now I have the ability to easily measure it, it’s become apparent.
Issue: I’m finding my lathe is cutting smaller than I’m reading on the DRO. To set my diameter I take a cut, leave the crosslide where it is and enter that measurement into the DRO. Then as I reduce the diameter, the actual diameter drifts away from the DRO and I end up overshooting the dimension by up to 0.2mm on a 10mm diameter.
What have I done.
1. I’ve tightened up all the gibs as one of them on the crosslide was loose after the install.
2. I put an indicator on the tool post to measure the actual change vs the DRO. This was perfectly in sync over 6mm but I did not check more than that as I assumed it was good.
3. I have checked my spindle bearing clearance and found it’s a bit loose. 0.04mm when I pull up (my lathe has plain bearings). Whilst I can imagine this doesn’t help, it seems too small to be the primary cause of my issues
What could be going on? What tests can I run to try and understand the cause of my issues. Am I using the DRO wrong? Not being able to rely on hitting a dimension is really frustrating, especially when I’m going smaller.
I thought the bed could be twisted but that seems like a huge twist to be missing dimensions by that amount. I’ll likely make a test bar tomorrow though to triple check.
What have I done.
