steelkestrel
- May 5, 2007
- bellingham wa
After repairing every drive axis from poor shipping and cleaning the machine from top to bottom it's time to address the bigger issues which I don't think are as bad as I thought they might be. Here are my current questions:
1. How much play should there be in the top transmission "floating" gear. The one in the center that is not on a splined shaft? Has anyone replaced that bronze bushing before?
2. What is the correct order of operations to make sure the gears are in the proper position and that the gear selector is also in the proper position to replace the gear box cover?
3. What is the paticular head on this machine called and is it suitable for general milling operations? Also should there be a level of oil in that head gear box?
4. How do I remove the site glasses on the z?
