I've been subscribed here for a while, but believe that this is my first post.
Almost got taking out this world today. I'm finishing up a die I'm building, and was in a lathe making some stop blocks. It's a big lathe, and I don't use it a lot, but the other lathes were occupied so there was no reason not to use it. I guess one good reason not to use it is the foot brake is broken on it. Anyway being a big lathe the tail stock is big and heavy so you have to put some weight into it to get it to move. I had it spinning at 670 RPM's and just finished facing one end of a stop block, and chucked up on a center drill to spot my thru hole, and put my body into pushing the tail stock toward my part and my Dickie shirt got rapped up in the feed shaft spinning and it started pulling me in. I quickly developed that crazy adrenaline strength and started to pull at my shirt tail, but it was rapping around that shaft real fast. I bent over and stuck my arms straight to let it rip my shirt off me. It started tearing the back of the shirt and ripped out the buttons, but on the way off my sleeve was caught on my right hand. This is where that adrenaline strength really came into play and I just ripped it out tearing the sleeve. My hand is pretty sore, and swollen, and I had a bunch of grease on the top off my hand off of the lead screw, that's how close it was to being pulled into the feed rod.
The crazy thing is, is the catalyst for this was a thread (clothing thread) hanging off the bottom of my shirt tail. A little string that they used to sow up the shirt with almost got me killed. After it ripped my shirt off we couldn't get it to pull off the rod. We slowed the lathe down, and put it in reverse, and after the shirt came off the shaft this little thread was perfectly rapped around the shaft about 3-4 times before the shirt even touched the shaft, and it was just strong enough to lift my shirt into the shaft, and let it start rapping it. I think the shaft having a light coat of oil covering it is what caused this lightweight sticking to stick to it, and start rapping around the shaft.
Life's a trip. It's crazy how a little string sticking to an oily rod can about kill you. I've been a tool maker/die builder since March of 04 so almost 19 years. You hear about people getting pulled into machines, but I've spent a lot of time turning parts, and never seen anything like this happen. I don't work in my wedding ring, I keep my hair short, I don't wear jewelry, and now I think I'm going to start tucking my shirt in when I'm running a lathe. It's easy to get too comfortable, and forget how dangerous the machines we use can be. I've got 3 little girls under 3 years old, and that would of been a real gurus scene if I'd gotten pulled into that lathe. That shirt and me pulling on it didn't slow it down one bit. I guess the good Lord decided that it wasn't my time to go.
Stay safe and aware people.
