Doozer
- Jul 23, 2001
- Buffalo NY
Making a shaft from D2 - What to look out for ?
This shaft is for the headstock of my Hendey T&G lathe.
It has 3 steps in it, 3/4, 5/8, and 9/16" over a 6" length.
Also has male 7/16-14 threads, a 1/8" woodruff keyseat
and a 5/32" keyway. I was going to cut the threads in the
lathe, and leave the step features (for needle bearings)
.010" oversize. Mill the keyseat and the keyway, then
heat treat and temper in an oven using stainless tool
wrap. I will grind to final size for the bearing journals
and where the gears go.
My question is, how tight do I make the male threads fit?
Will the D2 grow or shrink? I assume shrink.
Will my keyseats get tight ? I want the keys a light press
fit. Should I make the keyseats right on size and assume
they will close up a tenth or two? Is .010" oversize enough
grind stock? I don't know how much D2 will warp over 6".
I am not at all new to machining, but I do not heat treat
a lot of stuff. I typically use carbide tooling and buy pre-
hard stock in the 30Rc to 50Rc range, to get around the
need to heat treat. But this shaft had bronze bushings
that I would like to convert to needle bearings. Every
thing I read about needles say the shaft needs to be
at least 60Rc. I thought about buying Thompson shaft
but the needle bearings 3/4" and 5/8". Thinking if I
grind the Thompson shaft to 5/8" then it will be too soft
for the needle bearing. Hence my idea about making
the shaft from D2. Any cautionary thoughts before I
enter into this shaft adventure ?
Thanks,
Doozer
Thanks,
Doozer
