gcodeguy
- Jun 17, 2007
- Easton, PA
Had a small 30 piece order (35 slugs received). Drill size call-out was for a "Q" drill-.3320. Forget deph, but somewhere near 1.5 deep. Drilled after rough facing and turning. First piece the .3300 go-gage went to within about .3 from bottom. Bored .334 dia. x .48 deep for thread...just to be able to re-bore for nicer looking threads. After first part .330 gage wouldn't go past bored depth. Wall thichkness .053 before finish turning. I thought maybe it was expanding from the heat of drilling and then shrinking when it cooled. Nope. Ran drill back in after finishing part and go gage still wouldn't go. First time in almost 30 years of machining that I have drilled on a lathe, and the hole wouldn't accept a .002 smaller plug gage. Why? I am not surprised when a drilled hole (on a lathe) will accept a .002 LARGER gage. Yes the drill was on size. I measured it, and then had the other lathe programmer measure it. Both of us measured it as the correct size. Coolant was oil.
Drill brand unknown, but said Korea on it. HSS jobber length with a TIN coating on about half of it. Really nice looking point. Looked like it had never been used after I finished the job. Ran a "Q" carbide reamer to depth on a manual lathe to get on size. Brushed oil on reamer for every part. Part was pretty darn warm especially considering how little material it was removing. Ran cold water over one part and go-gage went just fine so no expanding / shrinking to speak of going on.
Considering the length of the flutes, I am wondering if the drill flexed causing the hole to not be straight. Maybe that is why the part got so hot with the reamer. It also looked like there were more chips from the reamer than there should have been. Don't remember my drill feedrate, but I know it wasn't heavy. My best guess while sitting at home would be .005 per rev.
Thanks for any feedback.
