Drilling Out Alumina Ceramic Tubing??
dazz
Aug 20, 2006
New Zealand
Hi
I ordered alumina ceramic tube for a one-off project. OD=4mm, ID=2mm.
I got tube OD=4mm, ID=1.2mm. The bore is too small.
It took over 2 months for the order to make it through the shipping process, so while I wait for a replacement, I thought I could experiment with what I have.
Is it practical to drill out the bore from 1.2mm to at least 2mm with conventional tooling (lathe)?? The bore only needs to be about 10mm deep.
The hole diameter, concentricity tolerances are wide. I want to epoxy or Loctite a 2mm pin in the bore. An oversized hole can be used to compensate for errors.
I have 2mm carbide drills but the risk of shattering would be great.
I am thinking of unconventional grinding using a soft core (plastic? matchstick?) coated with grinding paste. If the cutting end of the core is tapered from 1mm dia to 2mm diameter, the paste will be cutting over a relatively wide band.
Exotic methods like ultrasonic drilling are not viable.
Any suggestions?
Joe Gwinn
Nov 22, 2009
Boston, MA area
Hi
Bore it by wet grinding it on a lathe using a 2mm diamond point, using with lots of water. The point could he held in a tailstock chuck.
Or perhaps use a toolpost grinder, perhaps cobbled from a die grinder.
dgfoster
Jun 14, 2008
Bellingham, WA
You will never drill that stuff. But grind it with diamond as above? Yes.
Not sure the length of the bore or the accuracy of the bore needed. I see a number of tapered diamond points in that size range on Amazon, for instance.
If you could get water continuously to the actual area grinding, that would be a real plus. It would keep things cool and flush out the sludge. A diamond point is usually on very soft steel..Bore it down the center starting at the shank end. Then hook up water to the point itself. Might be very feasible if the point were held in a tool holder rather than your tailstock. No, I have not actually done it. But that is surely what I would try. Pecking will help flush out sludge as well. Alumina is very very hard and equally brittle. That is what my TIG cups are made from.
Denis
Joe Gwinn
Nov 22, 2009
Boston, MA area
Why is that ? Tungsten carbide is 2600 on Vickers scale, alumina ceramics up to 1600. There won't be a chip formation, but the drill should sort of grind its way in.
Drilling imposes far higher forces, especially in something as strong as alumina. Workpiece will likely break, and/or slip in the collet or chuck.
plastikdreams
May 31, 2011
upstate nj
We cut alumina ceramic cores at work with a diamond wet saw. It dulls carbide endmills quickly. It's removed from the castings with potassium hydroxide and sodium hydroxide...takes days.
dazz
Aug 20, 2006
New Zealand
Hi
Thanks for the advice and ideas.
Unfortunately there is absolutely no danger of getting diamond tooling where I live, and if I could, it would cost too many $$$.
It looks like any sort of carbide mill/drill won't work.
I am going to try a bamboo toothpick, with a tapered point and automotive valve grinding grinding paste. I have those already and nothing but time to lose.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
Hi
No stuff coming in from China? There's endless cheap diamond tooling and grinding pastes available off eBay and Alibaba and the like.
And how the heck did a Chinese Ecom company wind up with a name like Alibaba? Should have been 40Thieves Inc, or something like that...
crickets
Jul 3, 2021
Hi
Also check out Stefan's method for lapping such small bores :
https://youtu.be/o6UeWV_TRuc?t=1706
dgfoster
Jun 14, 2008
Bellingham, WA
Hi
Not familiar with a bamboo toothpick. But a soft( brass, aluminum, cast iron) lap charged with diamond past would get there. There are lots of schemes for making adjustable laps. I’ve made them and bought them. With coarse paste they cut quite well.
Denis
Conrad Hoffman
May 10, 2009
Canandaigua, NY, USA
1.2 to 2 mm is a very long ways for any sort of lapping. You need a spinning tool with diamond, lest you spend another 2 months getting the job done. Even an undersize cast iron pin with coarse diamond powder pressed in could work, though you'd need to recharge it often. A cheap plated Chinese tool would work much better. You don't want a 2 mm tool as the part will just break. Since it's 1.2 mm, start with a 1 mm tool. Hard to believe there's anyplace left without a Harbor Freight store! I'd think something on eBay would ship to you fairly quickly. You can mount a Mototool or any similar thing in the lathe toolpost to get the job done. Just shield it from the water you'll have to use to avoid electrocution. Or go with battery power.
memphisjed
Jan 21, 2019
Memphis
Dremel engraving sets have the tiny burrs of ok quality- big box availability. Why drill, ream, grind out the hole when there is a steel pin that can be turned instead?
dgfoster
Jun 14, 2008
Bellingham, WA
The key things we still don’t know is how long the bore is and how accurately and precisely it needs to be enlarged. Those factors determine whether a given solution is actually practical or not. Grinding with diamond paste for 2 mm is not the same as grinding 2 inches. +/- .000” is not the same as .O02.”
Denis
dazz
Aug 20, 2006
New Zealand
Denis
Hi
From my original post:
" The bore only needs to be about 10mm deep.
The hole diameter, concentricity tolerances are wide. I want to epoxy or Loctite a 2mm pin in the bore. An oversized hole can be used to compensate for errors."
dian
Feb 22, 2010
ch
thwo thoughts:
1. for mechanical material removal shrink a thick piece of tube (ring) on it.
2. if you want to play, get some potasium bisulfate and melt it in the hole. see what happens. maybe a silicone plug would work or teflon, no idea. you might get it in a winemaking shop.
